Thank you all for your input. I don't know why I didn't think of this earlier, but Eibach makes lift springs for them. It'll lift it a total of 2.5" in the front and 1" in the rear. Works with the stock suspension so I'll get that factory tuned ride but also clearance.
Is this also a bas idea? Everywhere I look people are very happy with this kit.
Can you post a link to the Eibach lift spings you're seeing? If I was to speculate the springs are probably right for a 2" lift but with the expectation that you're using a particular shock such as a Bilstein 5100 or 6112 or one from FOX, Toytec, Radflo, etc. It likely will not work on a stock shock and probably wouldn't even fit.
The advice you're gotten is all sound. I'll mention that i run mid travel FOX 2.5" diameter front shocks and so-called 2" lift King coil springs. I have them set to get about 1.5" of lift but since the shocks are 1" longer travel than stock this actually works out to be fairly close to staying in the middle of the travel range so that I in effect extended the up travel and down travel each by about 1/2" of an inch.
But by lifting I pushed the window down slightly so I still have more down than up. But being longer travel the impact isn't quite as bad about bottoming and a general harsh ride. I'm slightly over sprung (meaning too high of a spring rate for the weight and how much I compress the spring) so my ride is a bit stiffer than I'd like.
Should be mentioned that if you do use a front coil spring/shock that has any travel different than stock then you are required to run control arms to accommodate it. At minimum with mid travel you have to run upper arms that can take more travel. I still run stock lower arms, though. If you try to use more travel than the stock coil-overs you risk breaking the upper ball joint and that is *very* bad.
If anyone ever asks my suggestion is always to just get Old Man Emu. They work well, aren't too expensive and take most of the guess work out. You do need to know how much weight you're adding but they don't make suspension that will usually break anything on your truck. When you go down the Eibach/FOX/Toytec/Icon path you need to understand a little more about suspension to get what you want or really trust the shop making the suggestion. There are combinations of 5100 + coils that a lot of people use but unless you follow their set up
exactly (like where you put the coil collar for lift) you risk a completely different outcome.
