Actually, still looking for dust seals for the rear adjusters. They are a weird size and shape. Have tried a bunch of different parts off ebay but no luck yet. Also, the brake shoes I got for a toyota crown are close, but will need some drilling and grinding to work, so brakes are taking forever. Had parts come in from Thailand, Cyprus, Japan, Indonesia and the US, but still stumped on the brakes. Frustrating to wait weeks for a part and find it doesn't fit! After measuring the parts I am going to try some VW seals. They are the correct dimensions and the shape looks right. Waiting on those now..Only thing I'm still looking for (for the brakes) are the 10mm banjo fittings. I might have a couple more 9mm pieces in my 40 stash if I can't find the 10mm that are compatible with the M11 banjo bolts.
I did make some progress on the clutch system. The MC was in good shape but was dry because the slave was leaking. I took the master apart and cleaned it up. I luckily got a rebuild for the slave. It's really a weird unit, so I'm glad I could rebuild. It was seriously rusted on though. I've been hitting it with penetrating oil and I finally got the bolts to break free. Was really worried about snapping them off, would have had to pull the motor and Trans to drill and tap!
Here's the crusty slave cylinder. Yes, it uses the same, dreaded, 9mm fittings as the brakes! Had to remake the hard line. Luckily I had a few more 9mm fittings from my 40 brake parts.
Rebuild kit # for future reference
Gross! And leaky...
All cleaned up and ready for assembly.
I got the kid to come out into the cold, damp, dark garage and help me bleed the system. Seems to be leak free and working! Hopefully the clutch plate is alright. Once the brakes are back together I should be able to take it for a test drive finally!
