100 series remote key control unit - help needed
My 2002 Land Cruiser won't go into programming mode for pairing a remote. I even rented a programming unit from Tom's Keys with no success.
I'm guessing that the control unit that operates the remote keyless entry is either broken or has been disabled by a P.O.
Does anyone know where it is and what it looks like?
AimCOTaco
Longmont, CO
Matt, I have full FSM for my 99 so I'll look around.
I've had this problem recently using the method that takes locking and unlocking sequences to enter programming mode. I suspect my lock motors are too tired to hit the multi lock cycle timing as they tend to be strong for a few throws then slow down and need a rest. I assume the programmer thing does not require this?
AimCOTaco
Longmont, CO
W3 - Wireless Door Lock ECU, pdf attached.
DanInDenver
Try the gas pedal two step dance method. I have the same trouble with my door locks failing to cycle after about 3 lock unlocks.
The pedal dance has allowed me to program a couple of fobs to be recognized by the ECU and allows me to start the car.
I manually lock and unlock doors since I cant get to the programming mode for that function.
I have 1999 and 2000 LX470 so your mileage may vary.
DanielChase
Englewood, CO
Did you ever talk to my guy?
gungriffin
There is a limited number of transponders that can be programed if I remember correctly. There is a guy on ih8mud by the name of Mauser who is the guru on this. I believe the main computer behind the glove box handles everything regarding the keys. I didn't have a master key when I bought my 100. I removed the computer and sent it to Mauser. He was able to flash it to accept a new master key. He would for sure be the person I would ask about this.
MountainGoat
Club Treasurer
Evergreen, CO
Yeah, Boulder Toyota warranty replaced the ECU on our first 100 (a 1999 we bought used) because there was no room for a new transponder to be programmed on it. Seemed silly to me but I wasn't going to complain.
AimCOTaco
Longmont, CO
I think this Matt guy was looking to fix his locks rather than his security/start interlock.
Hopefully he'll post up and let us know how it's all working out.
Great 100 key thread so far!
