Hey gang, I have 2 new awning bracket solutions and I'm hoping to find someone here willing to test them. Which means you supply the truck with the OEM rack, and the awning, and I will give you the brackets for free, also help install them. Also use your truck for photos, and an install video. And if you need an awning also, I can help you get one of those as well I'm a dealer for ARB, Smittybuilt, Overland Vehicle Systems, and Rhino products.
Both of these brackets are to be used with your OEM rack- compatible with any Land Cruiser, and LX570 older than 2016, any GX470, any 4th or 5th Gen 4Runners, or any other Toyota that seems to have the same kind of rail..
First bracket is a solution for a more permanent mount- these wrap around your rail then bolt to it using some channel nuts, you can then attach your awning. here are the pics... shown with a Rhino Batwing installed. This is an upgrade to our Multi Bracket as it's simpler to install, and doesn't require an additional plate to mount the Batwing.
Until I come up with a better name, these will be called the "OEM Rail Awning Brackets."
