Frankengoat FJ62
satchel
Erie Co
Around 2007 I became involved in the white water kayaking scene, and my current mode of transportation was a Nissan Maxima. I strapped the boats on top of that thing for a year, but eventually the plastic started shaking off the interior trim from all the wash board roads and I began my search for a mountain beater.
I talked with my dad about the situation and he mentioned he had a friend looking to sell a 4wd truck, said it was a land cruiser and is "bullet proof" but maybe I should look into the galley plug fix. Sounded like snake oil but most of the trucks I was looking for had similar caveats. I didn't have much for cash at the time, but was able to trade my atv for it and thought that was a fair deal.
I'd never heard of a land cruiser, but I do remember looking up pics of the 60 series and hoping that the one that my family was bringing up would have circular lights, cause that looked cool. Instead, it came to me in a dull gray, square light configuration.
Not having any real 4wd experience prior to this truck, I took it to a nearby lot, made sure it was driving straight ahead, and put it in 4wd. It started bucking and hopping. I asked a bunch of people if that is normal and of course they all told me to get off of pavement in 4wd, but eventually the rising sun group helped me realize I had different gears front and rear, and that was corrected. Apparently one of the previous owners had blown the rear diff, and I'm assuming the mechanic that fixed it thought that the fj60 diff is the same as the fj62 and that is what he used.
My next two off road adventures did not fare much better.
Trip 1) Voltage regulator went out and the battery boiled over while trying to make contact for help
Trip 2) Went exploring around Silverthorne, had to put it in low range, and it didn't want to come out. Low range from Silverthorne to Aurora is not fun, though I was able to keep up with traffic.
I was getting to know it better. The truck had issues, but always got me home. More than I could say for some of the newer vehicles I had been driving at the time.
Once it came time to get Colorado plates, the real fun began. It didn't pass emissions, not even close. I took it to a local Toyota shop and the quote was 4k to get me where I would pass.
4k to get an old engine to pass made no sense to me, so I figured I'd swap in a vortec. I had just seen Marco's fj60 on the ghost town run and he walked me through the process a little. Seemed like a no brainer, so I went for it.
satchel
Erie Co
This has been my DD since I purchased it in 07, and unfortunately I didn't have a second vehicle for the majority of that time. That meant any upgrades I wanted to make needed to be done as quickly as I could. That will be my defense for why a lot of the work looks "good enough" anyway.
The 62 was stolen in 2017, and after a few months I decided I needed to move on and get a new DD, which is how I ended up with an LX450. Six months later the 62 was recovered, and I had done so much work to the LX I knew I would never recover the money/time invested, so I decided to keep both.
Now that I finally have a decent garage and a backup truck, I'm tearing the 62 back down in some areas to do them how I would have if I had the time initially.
Topics I'll try to cover as I get to them, less blab and more pics.
Engine
Water heater
Dual Battery
Brakes
Headlights
Cooling
Interior/Carpet/Gauges
Suspension
Seats - Planned
Paint/rust - Planned
Current setup for those that want to fast forward to the end. Not a great pic, but the only one I have with 35's (33's at the moment) and I'm sure there will be some wondering if 35's would fit on the new coil spring setup. I haven't tested the flex of 35's but they look like they should fit and I was told I should be fine up to a true 35 with a 2.5" coil lift, similar to an 80 basically.
Always great to see threads about FJ62s. Some say the last real Land Cruiser was the FZJ80 but, being biased as I am, the FJ62 can lay claim to that title too, imo. Yeah, it was the first Cruiser to have an automatic transmission but it was also the last to have a leaf spring suspension. A truck, in other words. It will be fun to watch how you proceed with the project, Satchel, as it will be a reminder of the similar processes I went through over 15 years ago. Good luck and have fun with it as it will be rewarding!
satchel
Erie Co
What I mess I have in here.
As mentioned before, I was in a bit of a rush to get the engine in a decade+ ago, so I'll let this pic serve as the before pic. I'm not tearing the engine down, but I am changing mounts and cleaning up wiring and all that mess.
A little info on the swap from long ago.
-Engine: 2002 Yukon XL 5.3 Flex motor. I kinda lucked out without knowing what I was doing. 1) This engine happens to have a return less fuel line. It has a regulator on the supply line, so no need to add one, and only needs the one supply line. Most need a supply, a fuel press regulator, and then a return feed. 2) The flex fuel model requires less fuel pressure. If I recall, it is something like 45psi vs 55psi on a normal 5.3. That means you can just hook it up to your normal fj62 fuel pump. Well, works in my case anyway and I have verified it is not getting starved.
-Throttle by wire: I kept the tac unit and installed the accelerator pedal out of a 2002 yukon I believe. I'll look that up. But I did have to reweld the pedal slightly.
-Headers: Used these from Advance Adapters, they have been fine. https://www.advanceadapters.com/pro...-generation-3-ls-series-v8conversion-headers/
-Transmission: Used an old 4x2 4L60E tranny (you need to have the 2wd version) that had a lot of miles, and it went out about 4 years ago. Super quick to take out and had it rebuilt new as a 4L65.
-Tcase adapter: 50-0408a from advance adapters. Gets the 4L60 or 65 to mate up to the stock tcase.
-Programming/ECU wiring: I used Wait4meperformance.com for reprogramming the ecu. Basically I sent them my ECU and the main wiring loom coming off of it, and they sent me back a reprogrammed ecu and wired up the main loom for like $400 or so. I don't have any experience in other trucks like this, but most people that deal with swaps like this are surprised when they punch it in my truck. I would assume I'm running around 320hp or so. Those guys did a great job.
satchel
Erie Co
Dropped the seats off with @rckhound on my way to the Rust Dr in Grand Junction.
Can't wait to see how they turn out!
Thanks again for taking this on!
rckhound
Durango, CO
Can’t wait to get it started. Nice meeting you and hope the best with your suspension issues.
satchel
Erie Co
Took the truck up to Jason, the Rust Dr, in Grand Junction to get some rust mitigation and frame protection going on. Some of the new suspension items started self disassembly, but I'll get to that later.
Some shots of the work so far.
IMG_1237.jpgIMG_1200.jpgIMG_1187.jpgIMG_1191.jpgIMG_1137.jpgIMG_1144.jpgIMG_1136.jpgIMG_1131.jpgIMG_1128.jpgIMG_1118.jpgIMG_1115.jpg
satchel
Erie Co
Repaint of the problematic rusty areas finished. This was done by Thompson Rod and Custom in GJ for a very reasonable rate.
shellb
Erie CO
That looks fantastic! I'm guessing based on your location we're really close to each other. Perhaps a meet-up and a beer is in order when you get it back from paint!
satchel
Erie Co
For sure. I'm always down for a beer and chat with a fellow cruiserhead. Seems like there are a number of us in the Erie area.
Looks like great work!
Now that the paint work is done, please tell me you will rustproof from behind with a grease-type rustproofing (plain old axle grease) smeared heavily on the backside of all repaired areas? With good metal, paint on the front, and grease on the back, you will be good to go for many years.
satchel
Erie Co
Reassembly. So far I'm really happy with how well the lower paint job matches with the truck. Way better than I anticipated for the price I was charged. Hoping to have it back this weekend to start reworking the coil suspension.
satchel
Erie Co
Got the seats that @rckhound recovered installed. So much better!
Radio crapped out on me so I threw in a new touchscreen setup with front and rear cameras.
And since I had to ditch my rear locker with the new axles I added a winch for a little extra off road security.
satchel
Erie Co
So ever since I put the 5.3 motor in my truck I've had issues with my coolant overflow bottle overflowing. Regardless of engine temp, even slightly pressing the accelerator causes coolant to expel from the radiator. I've done the cheap chemical tests to see if combustion gasses are getting into the coolant and it appears it is after I do it enough times.
I will be doing a full overhaul on this truck in a couple of years, but working on other projects at the moment.
I decided to do a quick look into the gaskets assuming I probably had a failure there and I guess I'm not sure how to tell from a metal gasket if there is actually a failure. I was surprised to not really see much going on gasket wise. Should there just be cracks or physical damage to the gasket or can I assume if it still looks like a flat metal gasket that is was performing as normal?
Seems like I should see something worse than this so now I'm debating taking the head in to get it inspected at a machine shop to make sure it isn't warped. While I'm sure at this point I could use a full rebuild on the engine, I need to save that for a little further down the road due to space.
Anything you guys see that makes sense to address immediately vs waiting a year or two to do it patiently and correctly?
Seems odd one side has such a variation in push rod color.
No visible cracks or anything in the metal gaskets that I can see.
Not sure what's going on there but gonna do some cleanup and see.
