I updated my original post with some new information/details that I thought of and added this section
Day 2 (or "the steering shaft on my Land Cruiser is as big as the drive shaft on your Corolla"): April 27, 2009 - 1 1/2 hours Tools needed 1. Various box end wrenches (loving my stubby Gear Wrenches)/ratchet/sockets (Note: the u-joints are pressed in the intermediate shaft, and with two simple measurements (diameter and cross length) any parts store should be able to match the u-joint and it should cost around $25. Some say it's a matching u-joint to a mid-70s (1.2L) Corolla driveshaft. EDIT: got it today. It's manufactured by GMB (a Japanese company), distributed by Precision Universal Joint (a Federal Mogul Company), and I got it at NAPA. NAPA Part Number 395. Federal Mogul Number FM68-401225. By the way my parts guys at the dealership know what years and engine designation the 1.2L Corolla engine was - that's how good they are )Tonight's attempt was to get the intermediate shaft mocked up so I could locate the steering box fore/aft on the frame and make sure my shock towers would be okay (fore/aft) and not interfere with the fender supports. 1. First you have to remove the u-joint ends on the FJ55 intermediate shaft, using simple tools. 2. Next make sure you have your new u-joint from the parts store and use the u-bolts to clamp the u-joint ends together around the u-joint and you're on your way! Spline to spline connections with a u-joint in the middle! FJ55 intermediate shaft/slip joint, from which the u-joint ends will be stolen ![]() u-joint ends taken apart ![]() u-joint reassembled with new u-joint from Corolla ![]() ![]() So now I am done until next week when I get my drag link parts in and get my u-joint for the intermediate shaft. I waited on ordering the drag link parts until I got some closer measurements - it's kinda expensive to do it this way but I wanted to try it and see if it will work. Punch List: 1. I need to start a list of mounting hardware I will need to get (I want to stay JIS metric for as much of this as possible) - box mounting bolts, exhaust clamp bolt, intermediate shaft bolts, etc. 2. I need to get my u-joint for the intermediate shaft to mock up my box fore/aft. EDIT: As of 4/28/09 I have this in hand 3. I am waiting on my drag link parts (FJ40 TRE and BJ70 drag link end) to mock up my box side-to-side. EDIT: As of 4/28/09 I have the TRE in hand. Still waiting on BJ70 drag link end - those Canadians are slow eh? 4. I need to get the FJ55 column keyswitch removed by a locksmith (I don't have a key so I can't do it the kosher way and I don't want to destroy it) so I can use my current keyswitch. 5. I need to mock up my shock towers and see what modifications will need to be made. 6. I have to get some plates (at least one, maybe two 1/4" plate) cut and drilled to the bolt pattern of my steering box. 7. I have to get some pipe for sleeving my frame, cut to length. 8. I have to sharpen a bunch of drill bits so they are ready for use. 9. I have to get the frame drilled to the bolt pattern and bored and chamfered so the sleeves are ready to weld in. 10. I have to remove anything that will be in the way of the welder. 11. (Welding day) a. A plate will need to be made to fill in the flex hole in the frame, ground flush. b. The mounting holes will need to be extended through this new plate. c. The sleeves will have to be welded in place. d. The reinforcing plate(s) will have to be welded in place. e. I have to get a plate made in place of the EGR pipe that connects to the exhaust manifold. f. I need a change made to the back end of my exhaust - tab with bolted connection. g. I need my windshield frame support brackets (where the knobs screw in) to be rewelded in place so I can drive around with the the top (including bikini top) off. 12. There's a plate on my frame, welded in front of my steering stabilizer. It isn't really doing all that much good (maybe a little bit), but it's mostly in the way, so I'm going to have to cut that off. 13. The drag link, steering column, and intermediate shafts will have to be bolted up. 14. The shock towers will have been located and mounting holes drilled, but I will need to do some measuring and figure out what shocks I need to get (thinking Bilstein). Also figure out what steering stabilizer is needed. 15. Trim fender(s) to accept steering box and shock towers. 16. Make sure high pressure hose works properly. If not figure out what needs to be done to make it work (research thread pitches if necessary, rebend hard sections to position loop in hose where I want it to be). 17. Figure out what I'm going to do about a return line cooler (I decided I'm going to buy a tubing bender for $15 and try to rebend the tubing to fit where I want it to go, in front of the radiator behind the grille). 18. Get my steering all centered, get everything buttoned up, flush power steering system and go for a drive!
Matt Miller -.- -.. ----- -.. .... .--- TLCA# 13684 Rising Sun Bio 1977 FJ40 2F "Brahma" + Lockright, tach, Warn 8274 and Power Steering! ![]() ![]() 2000 Tundra Limited TRD 2UZ-FE 2008 KTM 250 XCF-W ![]() http://www.daveramsey.com ![]() Last edited by subzali; 04-29-2009 at 09:26 PM. |
I just finished doing an 80 box in mine, pretty much the same box as the 60 but newer. You may not be real happy with an 55 column. I decided against it after someone doing this said he hated it, I'm not sure why.
The column parts are all low carbon cast steel, so they are weldable without special treatment. I just TIG welded a U joint on to where the base plate had been after turning the parts in the lathe for a running fit. Same with the TRE and relay rod, used the left half off a FJ60 and turned the end to fit in the right half of a 40 relay rod and TIG'd that. It all came together better than I'd hoped, no real grief. Let me know if you need any dimensions or pics. |
Day 3 (or "If I was a redneck I could be driving this baby tonight!"): April 29, 2009 - 2 hours
Tools needed 1. Various box end wrenches (loving my stubby Gear Wrenches)/ratchet/sockets 2. Bench grinder 3. Vice grips/pipe wrench (Note: The steering shaft u-joint will need to be clearanced in order to work properly. It doesn't need much, the angle is very low. Tonight I assembled my u-joint and did a test fit of my intermediate shaft to find my steering box's fore/aft location. I also got one step closer with my drag link, by installing the FJ40 tie rod end in the new drag link. It worked like a charm and exactly as I was hoping for. 1. If you like you can fit up the new u-joint, but you will quickly find that the two halves interfere with each other, so you will have to disassemble it. 2. Mark the corners and take them to a bench grinder, test fitting the halves a couple times to see how much you have to take off to get them to rotate. 3. Now you can assemble the u-joint and then bolt it on to the intermediate shaft. 4. Since the new steering column is in place, bolted to the firewall, you can plug the intermediate shaft into it, then move the steering box to attach to it on the other end and boom! You have the fore/aft location of your steering box. I found that there will be plenty of room for the F-250 shock towers in front of the fender support, and in fact they should line up perfectly with the stock mount on the axle. The u-joint hangs over the edge of the frame, though, so it looks like at the very least the shock tower will have to be left in its stock bent location and fender trimming will have to be done. I will have to wait and see if any more spacing will be needed once I finalize the side-to-side location of the steering box. 5. Take the FJ40 tie rod end and thread it into the 70 series drag link. I was surprised at how many threads there were on the TRE; I didn't remember that many but that's a good thing; it means there is lots of room to play. Here's an excerpt from some posts in TJ's thread: Quote:
![]() 6. I measured up the distance from the end of the drag link tube and if the BJ70 drag link end (that connects to the steering box) is between 4 1/2" and 5 1/2" long it will be just the right length. And you know what? I measured Wes' at 4 3/4". How lucky can you get? At this point I could have pulled the FJ60 drag link end and threaded it into my new tube and connected it to the pitman arm. I could have taken my high pressure hose and threaded it into the power steering pump and into the box, hooked up the low pressure line, put the steering wheel on and taken the truck for a joy ride (with the steering box clamped to the frame with c-clamps)! Aren't you glad I'm not THAT redneck!? ![]() Okay, for some pics: Precision u-joint box ![]() Precision Part number ![]() u-joint in GMB bag ![]() showing u-joint interference ![]() ground down corners ![]() intermediate shaft hooked up ![]() checking out about where the steering box will be located. Notice the low angle of the intermediate shaft. The four bolts on the far right are the mounting bolts for the fender support. There should be plenty of room to mount the shock tower between the fender support and the steering box, and maybe even align it with the shock mount on the axle. ![]() Showing the amount of threads available on the FJ40 tie rod end ![]() Plugged the drag link into the tie rod. Looking good! ![]() Measuring from the end of the drag link to the pitman arm. I think it's going to work! ![]() trying to show the drag link angle - it's pretty close to parallel with the tie rod ![]() So now I am done until next week when I get my BJ70 drag link end in. The FJ60 steering box will hit the radiator support if it's mounted directly to the frame, so I will have to have a spacer plate made (about 1/4" or so I think). This will require the drag link to be slightly longer than I was measuring above, but will actually end up being pretty perfect I think. Now that I have the steering box kinda sorta located fore/aft, I'm going to take the steering column in to a locksmith and have them match the lock cylinder to my key set. Punch List: 1. I need to start a list of mounting hardware I will need to get (I want to stay JIS metric for as much of this as possible) - box mounting bolts, exhaust clamp bolt, intermediate shaft bolts, etc. 2. 3. I am waiting on my drag link parts ( . It's cheaper to order the rebuild kit with all 4 ends than it is to order just this one...going to wait and see if they come up with any solutions...Specter's kit is $179. EDIT AGAIN: Don was able to find a 70 series drag link end for a "reasonable" price and it should be here this week.4. 5. I need to mock up my shock towers and see what modifications will need to be made. EDIT: As of 4/29/09 I know I will need to bend the shock towers back to their original location. Maybe I can get rid of these to somebody who wants straight F-250 shock towers and I can go buy me some new bent shock towers? Any takers? 6. I have to get some plates (at least one, maybe two 1/4" plate) cut and drilled to the bolt pattern of my steering box. 7. I have to get some pipe for sleeving my frame, cut to length. 8. I have to sharpen a bunch of drill bits so they are ready for use. 9. I have to get the frame drilled to the bolt pattern and bored and chamfered so the sleeves are ready to weld in. 10. I have to remove anything that will be in the way of the welder. 11. (Welding day) a. A plate will need to be made to fill in the flex hole in the frame, ground flush. b. The mounting holes will need to be extended through this new plate. c. The sleeves will have to be welded in place. d. The reinforcing plate(s) will have to be welded in place. e. I have to get a plate made in place of the EGR pipe that connects to the exhaust manifold. f. I need a change made to the back end of my exhaust - tab with bolted connection. g. I need my windshield frame support brackets (where the knobs screw in) to be rewelded in place so I can drive around with the the top (including bikini top) off. h. I need to have a spacer plate welded to my shock tower (maybe?) 12. There's a plate on my frame, welded in front of my steering stabilizer. It isn't really doing all that much good (maybe a little bit), but it's mostly in the way, so I'm going to have to cut that off. 13. The drag link, steering column, and intermediate shafts will have to be bolted up. 14. The shock towers will have been located and mounting holes drilled, but I will need to do some measuring and figure out what shocks I need to get (thinking Bilstein). Also figure out what steering stabilizer is needed. 15. Trim fender(s) to accept steering box and shock towers. 16. Make sure high pressure hose works properly. If not figure out what needs to be done to make it work (research thread pitches if necessary, rebend hard sections to position loop in hose where I want it to be). 17. Figure out what I'm going to do about a return line cooler (I decided I'm going to buy a tubing bender for $15 and try to rebend the tubing to fit where I want it to go, in front of the radiator behind the grille). 18. Get my steering all centered, get everything buttoned up, flush power steering system and go for a drive!
Matt Miller -.- -.. ----- -.. .... .--- TLCA# 13684 Rising Sun Bio 1977 FJ40 2F "Brahma" + Lockright, tach, Warn 8274 and Power Steering! ![]() ![]() 2000 Tundra Limited TRD 2UZ-FE 2008 KTM 250 XCF-W ![]() http://www.daveramsey.com ![]() Last edited by subzali; 05-05-2009 at 10:59 PM. |
Matt,
This is an outstanding thread!!! That is disappointing news about your drag link end! I have a few questions: - Are you certain that the 70 series drag link end and the 40 series DS TRE are opposing threads (so that you can thread them into both ends of tube)? - Why not go w/ 70 series ends at both ends of the relay tube? - what is the rule of thumb about how much thread depth you should have on a TRE in tie rod/relay rod/draglink? Is it 2.5x thread diameter or something like that?
TJS 1978 FJ-40 1974 FJ-55 w/ 3FE TLCA #10713 CO/WY Horsetooth 4 Wheelers Cruiser Club - Click Here! Quote:
[break for Cruise Moab...]
[/break for Cruise Moab] ![]() Quote:
(especially since lowenbrau on MUD said it would work)Quote:
I don't know, whatever looks right I guess. I guess I would like to have more than what is shown in the picture above, but we'll have to see where it comes out when it's all together.
Matt Miller -.- -.. ----- -.. .... .--- TLCA# 13684 Rising Sun Bio 1977 FJ40 2F "Brahma" + Lockright, tach, Warn 8274 and Power Steering! ![]() ![]() 2000 Tundra Limited TRD 2UZ-FE 2008 KTM 250 XCF-W ![]() http://www.daveramsey.com ![]() |
Matt,
Why don't you just have Front Range Off-Road Fabrication make a drag link to your specs? I had them make one for me and it was much cheaper than ordering one from any of the usual suspects and burlier too. ![]()
75 FJ40 with stuff; and now weighing in at 4370 lbs. |
I'm trying to see if this can be done with all Toyota pieces/parts (even though I'm using a Saginaw pump/bracket I know some people can use an FJ60 pump because their blocks will accept the bracket). But yes the more cost-effective way would be to have a custom one made, if I weren't on a mission to make this work then that's what I would have done. But thank you for the link because someone else who reads this thread in the future will probably want to go that route and they'll know who to go to.
Day 4 (or "Cruise Moab "El Guapo" was great but now it's back to work - gotta keep momentum"): May 5, 2009 - 2 hours
Tools needed 1. Various box end wrenches (loving my stubby Gear Wrenches)/ratchet/sockets 2. Punch/Hammer 3. Vice grips Tonight I installed my newly rekeyed FJ55 column assembly, installed my newly acquired sun visors (finally!), and made my intermediate shaft collapsible. I am still waiting on my drag link end (should be here any day, they already charged my card which tells me it shipped), so I am working on some other things; the big ones are getting my mounting bolts lined out so I know what kind of drilling is going to need to be done, and get my reinforcement plates drilled to the box bolt pattern. I also have to get the pipe I am going to use for the sleeves. 1. First I installed my sun visors, just to get that out of the way .2. Next I started to reinstall my steering column. I got to thinking about how it's longer than the stock one, and found out it's exactly 1 1/2" longer. I got to thinking about why that was and got to wondering if there was a way that the outer part of the steering column from the FJ40 could be made to fit on the FJ55 steering shaft. So I took it back out and looked at it closer. They are different designs, the FJ40 uses a bushing at the base of the column, which like TJ's was all worn out and crumbly, probably adding to slop in the system. The FJ55 uses a bearing and the base plate is removable, so if I cut the mounting flange off the FJ40 column and cut it to the proper length I could probably get the FJ55 flange to slide right in and I could shorten the column up a bit; good info for the future in case I don't like how close the wheel is to me. It actually wouldn't be that hard to do. 3. Well figuring that that was out of the scope of this project and I would have to write myself a change order for that job (here's work creeping in to my personal life ) I bolted it back in and got it all reassembled. I couldn't find all the screws to fix the plastic clamshell on, but oh well I guess. They're around somewhere .4. Next I took the intermediate shaft and looked at the pins that hold it rigid until it gets impacted. TJ told me they are just plastic, and that they would break the first time the frame flexes away from the body. But I wanted to find out just how much travel in both directions I had so I took out a piece of wood and slammed the shaft down on it, splines first (like popping a birfield bell off your inner axle shaft) and with a bang the two pieces slid into the collapsed position. I took them apart a few times and took some measurements, it's 24 1/4" long in the uncollapsed condition (from end of u-joint to end of splines) and 19" long collapsed. They don't give much room to extend, but I figure the movement there will be very small so I'll just remember that I have 5" or so that the splines could get closer to the steering box before I have problems. That might come in handy some day when I decide to shorten my steering column up a bit. I also realized that I could move the steering box back an inch or two on the frame because of the collapsible intermediate shaft; of course it will have to clear the shock tower, but it would be nice to have the box far back enough to be able to clear the radiator support and mount the box directly to the frame (given the J7 drag link end allows it, i.e. isn't too long). Am still waiting to see what all will happen with that. 5. I then took some bolts and clamped the u-joints to the column and intermediate shaft splines and fit it up once again. I also disassembled the unnecessary bearing that would be at the base of the FJ60 column if it was installed in a truck, to clean up the shaft a bit. 6. After all that, I took a look at my drag link shafts to try and figure out the answer to TJ's question above. On the FJ60 drag link, the pitman arm "end" is Left Hand Threaded while the tie rod "end" is Right Hand Threaded. I'm assuming it will be the same for the J7 drag link ends, so since the FJ40 TRE I am using on my drag link on the tie rod "end" is Right Hand Threaded, the J7 drag link "end" at the pitman arm should be Left Hand Threaded. So in theory this all should work. 7. Lastly I've been investigating the connections to the steering box itself. There's some threads on MUD that are very confusing. But here's what I think (stolen and modified from Mace/TJ on MUD): Metric HIGH Pressure Port - 16 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF06 or 'Summit Racing' #EAR-9919DFJERL LOW Pressure Port - 17 x 1.5 MM Inverted Flare to #6 JIC Male adapter, Toyota - 'PSC Motorsports' #PSC-SF07 As I understand it the SMALLER port is the press side, and is the outboard connection. Or LEE MFG. CO in Sun Valley CA 818-768-0371 has 16mm x 1.5 inverted flare to #6jic for the PRESS side and 17mm x 1.5 inverted flare to #6jic for the RETURN side for $8 each Sag pump pump side is 5/8 x 18 inverted flare to -6jic, which BTW is close enough that the 16mm x 1.5 will thread in and seal. JT Outfitters sells a hose, which I have, that has the exact same fitting on both sides. That leads me to believe that the 16mm x 1.5 HAS to be the PRESS side because it matches the the thread on the steering pump. Some also say that I could get a replacement FJ60 high pressure hose and it will do the same. So they have to be the same! *So can someone with an FJ60 verify for me that the high pressure side is the outboard side of the pump?* Thanks. I'd like to get the 17mm x 1.5 fitting on order for the low pressure side so I can plumb it up. Okay, for some pics: Toasted bushing at base of steering column ![]() Steering wheel back in the vehicle ![]() Intermediate shaft with stops punched out so it can slide ![]() Two halves of the collapsible intermediate shaft ![]() Intermediate shaft with bearing taken off ![]() Intermediate shaft hooked up ![]() Up close picture of the u-joint at the firewall ![]() FJ60 Drag Link end for pitman arm side - showing Left Hand Thread ![]() FJ60 Drag Link end for tie rod side - showing Right Hand Thread ![]() So now I have to wait for my drag link end. Get the reinforcement plates made and the sleeves figured out. Drill out the holes so they're in their proper place and can get made to go through the frame on welding day after the frame is closed in on the back side. I have to get the fitting ordered for the the steering box. I am going to buy a tubing bender to try and tweak the return line cooler that I have so it will work for my truck. I have to remove the plate on the front of my frame that is keeping me from getting at my steering damper to remove it. Then I have to clean up the frame and prep it for welding day. Punch List: 1. I need to start a list of mounting hardware I will need to get (I want to stay JIS metric for as much of this as possible) - box mounting bolts, exhaust clamp bolt, intermediate shaft bolts, etc. 2. 3. I am waiting on my drag link parts ( . It's cheaper to order the rebuild kit with all 4 ends than it is to order just this one...going to wait and see if they come up with any solutions...Specter's kit is $179. 4. 5. I need to mock up my shock towers and see what modifications will need to be made. 6. I have to get some plates (NOW!)(at least one, maybe two 1/4" plate) cut and drilled to the bolt pattern of my steering box. 7. I have to get some pipe (NOW!)for sleeving my frame, cut to length. 7a. I have to cut off the plate that's in the way of the steering stabilizer (some PO did it )7b. I have to figure out what kind of bracketry will be needed for the Sanden air pump 7c. I have to get a low pressure return fitting for my steering box 8. I have to sharpen a bunch of drill bits so they are ready for use. 9. I have to get the frame drilled to the bolt pattern and bored and chamfered so the sleeves are ready to weld in. 10. I have to remove anything that will be in the way of the welder. 11. (Welding day) a. A plate will need to be made to fill in the flex hole in the frame, ground flush. b. The mounting holes will need to be extended through this new plate. c. The sleeves will have to be welded in place. d. The reinforcing plate(s) will have to be welded in place. e. I have to get a plate made in place of the EGR pipe that connects to the exhaust manifold. f. I need a change made to the back end of my exhaust - tab with bolted connection. g. I need my windshield frame support brackets (where the knobs screw in) to be rewelded in place so I can drive around with the the top (including bikini top) off. h. I need to have a spacer plate welded to my shock tower (maybe?) 12. 13. The drag link, steering column, and intermediate shafts will have to be bolted up. 14. The shock towers will have been located and mounting holes drilled, but I will need to do some measuring and figure out what shocks I need to get (thinking Bilstein). Also figure out what steering stabilizer is needed. 15. Trim fender(s) to accept steering box and shock towers. 16. 17. 18. Get my steering all centered, get everything buttoned up, flush power steering system and go for a drive!
Matt Miller -.- -.. ----- -.. .... .--- TLCA# 13684 Rising Sun Bio 1977 FJ40 2F "Brahma" + Lockright, tach, Warn 8274 and Power Steering! ![]() ![]() 2000 Tundra Limited TRD 2UZ-FE 2008 KTM 250 XCF-W ![]() http://www.daveramsey.com ![]() Last edited by subzali; 05-06-2009 at 01:04 PM. |
Hey Matt - Max may be interested in the shock towers if they're still available....I'll ask him tonight.
Great job on detailing your steps! Max is about to begin a similar conversion and I'm sure he'll really appreciate all this great data. Rob |
nice work. keep it up
Name: Farnham 98 uzj100. Factory rear-ARB front locked. ARB Bull, Warn 9000, Irbis rear bumper, Slee sliders and belly pan. OME t-bars w/863 rears KD0GWO Largeone "While the LandCruiser was really their first, they have made the new LC such a yuppie vehicle, they need to consider taking LC out of the name completely" Randy-"wondering how I'll get home 'cause Tom threw the keys in the fire" |
| Thread Tools | |
