Old 07-23-2007, 08:56 PM
Default FJ45 Tailgate Lettering
Last summer, to improve the appearance of Rita the red truck for the Rally, and also to prevent minor surface rust from turning into cancer on a rare endangered species (bone-stock FJ45), I spot-sand blasted the bed of my FJ45 pickup where the rust had bubbled up through the factory paint. Then I sanded and feathered with orbital air and then by hand. After priming with filler-primer and coming back and hand sanding again for many hours, I rattle canned with the finest Ace stop-rust and made a mental note that it sucked that I had to paint over the original TOYOTA white lettering on the embossed tail gate.
Steve Helmreich made adhesive decals for the lettering on the tail gate of his FJ45, and I wanted to buy a set from him, but his were one-off and I wanted to get mine done. With the weather warm and dry recently, it seemed as good a time as any.
I finally set some time aside this past weekend and started in with the masking tape. At first, I thought I could simply carefully apply the tape along the top edges of the embossing, but after several hours and two tries, I decided that simply wasn't going to work. Starting over, I simply taped over all the embossing:
Old 07-23-2007, 08:57 PM
Next, I put on some reading glasses (yeah, it sux to get old :-) and VERY carefully cut the tape were the apex of the embossing seemed to be.
Old 07-23-2007, 08:58 PM
After that it *seemed* pretty straightforward to mask everything else in sight.
Old 07-23-2007, 08:59 PM
Then 5 coats of Ace's finest epoxy enamel.
Old 07-23-2007, 09:06 PM
The finished product. Not bad. However, I was ALARMED to discover overspray UNDER the newspaper, and a tiny bit of bleed under some of the masking tape seams. The overspray was corrected with some scotchbrite after it had dried, and the bleed was taken care of with a little bit of hand touch up with some red applied with q-tip. Next weekend I'll rough it down a bit and then apply a couple coats of clear coat. Overall, much better than all-red, and certainly better than rust bubbling through!
These types of projects are kind of fun: No bleeding knuckles or hernias, no spills on the garage floor, very inexpensive, and it looks a heck of a lot better when done than at the start :-)
Happy cruisin'!
Old 07-23-2007, 09:40 PM
Looks great Jeff! Now all you need is the chrome 4x4 decal in the oval. Someone on MUD is making replicas, I'll see if I can track down the link for you.
Old 07-23-2007, 10:18 PM
Sweet. I like it.
Old 07-24-2007, 01:11 AM
VERY nice
I wonder if the "blue" tape that some use would bleed less? I used that when touching up my Moab scars on the LX. It seemed to leave a nice definitive line but then again it was black on black so hard to tell.
Old 07-24-2007, 09:22 AM
Looks like SOR has the 4x4 decal for the tailgate:
SOR decal
Old 07-24-2007, 09:56 AM
Jeff - your painted letters look great!
Sorry I was such a slug about making letters or having more made. About the time I was on it, some guy posted on Mud that he was selling sets. I have no idea who.
