Go Back   Rising Sun Member Forums > For Sale / Wanted
Old 08-12-2009, 03:34 PM
Air Randy's Avatar
Default FJ40 full quarter panel skins
I started out looking for a cheap used qp corner so I could cover up the hole left when I removed the rear aux tank fuel filler. Then Kevin (BIGBLUEFJ) was kind enough to offer a set of used full QP skins for a reasonable price and tote them down to the rally.
Well, before I got them installed I decided I liked the tread plate look better than smooth and ended up ordering a full set of tread plate QP skins and kick plates from Aqualu
So, once again, my attempt to save money mushroomed far out of control and I ended up spending a bunch more than planned but it should look good when it's done.
So, anyone with rust holes, dents or a desire to change the shape of their wheel well opening in their quarter panels, I have these available. They're in pretty nice shape. Kevin sold them to me for $70 so thats what I'm asking for them. Thanks-Randy 303-319-8976
Randy Rosetta TLCA #19351 74 FJ40 "Blue Mule" and 85 X-Cab mini-truck "The Gecko"
Old 08-12-2009, 10:27 PM
EWheeler's Avatar
EWheeler EWheeler is offline
They look to be 3/16 or so thick? If they aren't just sheet metal I will take them.
Evan
Old 08-13-2009, 01:01 PM
Air Randy's Avatar
Evan
I think they are aluminum
Old 08-13-2009, 05:34 PM
EWheeler's Avatar
Just responded to you PM asking if they were Aluminum. I am looking for steel replacements for the current sheet metal quarters that I can weld in. Looks like these won't work. Thanks for the response.
Evan
Old 08-13-2009, 08:37 PM
Rally Committee Member
Steel rocks. It rusts after a long time, but is the shazam. Evan, how tech are you? You can build your own on the cheap...
1971 & 1976 FJ40s, 1978 FJ45
Rising Sun 4WD Club, TLCA #4063, TLCA President
http://Rzeppa.org
Old 08-13-2009, 09:42 PM
EWheeler's Avatar
I could definitely make my own with sheetmetal. I have read multiple threads on tack welding as you go along and bending the sheet metal around the hardtop rail. Turns our good enough for a trail rig. I want my quarters made out of plate steel though so I can scrape them along obstacles and not dent them up. My plan is to raise my inner fenders and also raise the wheel well line with a "comp" cut, so with losing all the metal, I am not too worried about the added weight of the plate.
Old 08-17-2009, 09:37 AM
Rising Sun Land Use Coordinator
The Bud Built panels look really stout:
http://forum.ih8mud.com/pa-appalachi...66-fj40-3.html
-- MARTIN - '73 FJ40 - '85 FJ60 - TLC#16348 - KDØGWM --
Old 08-17-2009, 01:22 PM
EWheeler's Avatar
They are nice, but awfully expensive for something I am going to hack up into a comp cut.
HTML code is On
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
